Unmanaged Switches
Ruijie RG-S1800 Series Unmanaged Switches deliver basic network connectivity and reliability for small businesses which are easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Ruijie, with no installation software and zero configuration required. Just plug it in, connect your computers and other business equipment, and the device will be ready to use.
Ruijie RG-S1800 Series Unmanaged Switches are a line of unmanaged switches that provide wire-speed Gigabit Ethernet connectivity to connect your small business office. Available in desktop and rack-mount models, these switches are designed to suit any office space with basic network needs and to optimize power efficiency.
The Ruijie RG-S1800 Series Unmanaged Switches are suitable for video surveillance networks and support PoE+. They can be used for parks, office buildings, residential, parking and other video surveillance environments for camera access. The switches have larger port buffer to ensure a smooth video transmission.
Feature Highlights of RG-S1800 Series Unmanaged Switches:
●Affordable 10/100/1000Mbps speeds for even the most bandwidth-hungry applications
●Desktop or rack mountable models with 8 to 26 ports
●Power over Ethernet Plus models to provide power to IP phones, access points, cameras and other devices
●Work right out of the box: plug and play with no setup
Designed for IP Surveillance Scenario
Rich Port Types
Applicable to Various Scenarios
Standard SFP Ports
No Optical-copper Converter Required
Smart PoE Functions
Greatly Improving Terminal Stability
Large Buffer Design
No Stuttering of HD Videos
RG-S1800-P Series
PoE+ on All Ports
Rich Port Types
The RG-S1800 series offers a
broad range of port types,
including 8/16/24 FE/GE access with
copper/SFP uplink, which can be
used in various SMB scenarios
and IP surveillance scenarios.
Standard SFP Ports
The RG-S1800 series (except for RG-S1808,
RG-S1808G and RG-S1809-P) is equipped with
standard SFP ports, which prevents SPOF and
reduces costs by 20%.
Large Buffer Design
The large buffer design is especially
designed for IP surveillance and
ensures smooth HD video
transmission.
PoE+ on All Ports
Making Your Network More Efficient and Economical
RG-S1800-P series supports high-power (30W)
electricity supply, which is applicable to various
terminal types.
Smart PoE Functions
Improving Terminal Stability by More Than 30%
RG-S1800-P series can automatically negotiate the power based on the terminal type and provide short circuit protection. The switches automatically power off upon a short circuit.
Ruijie Networks
