Hogar> Producto> Conmutadores > Conmutadores de acceso>
RG-S2900G-E V3 Series Switches
Más+
NFPP Network Protection
RG-SNC Topology Management
Design For Durability
RG-S2928G-E V3
RG-S2952G-E V3
24 10/100/1000BASE-T ports
4 1G SFP ports (non-combo)
48 10/100/1000BASE-T ports
Fan Slots
Fixed
Management Ports
Up to 256Gbps
Up to 96Mpps
Up to 132Mpps
Up to 16K
Routing Entries
IP Host Entries
(IPv4/IPv6)
Up to 1,500
AP, LACP, Flow balance
Up to 128
Layer 3 Features
Layer 3 Protocols (IPv4)
Static routing, RIPng, OSPFv3
RAS
(W x D x H) (mm)
440 × 260 × 43.6
≤3.5kg
≤4kg
482560 hours
372690 hours
Lightning Protection
6KV
Frequency: 50 to 60Hz
≤24W
≤40W
Storage humidity: 5% to 95%RH
IEC 60950-1,EN60950-1
Emission Standards
The RG-S2900-E/P V3 gigabit secure and intelligent access switches are ideal for the following and scenarios alike
Full gigabit access to LANs of large-scale enterprises and institutions, such as government buildings, large manufacturing, energy, and metallurgy enterprises Full gigabit access to server clusters
Secure access through flexible and diverse security control policies that can defend and control network viruses and attacks
Full gigabit access to business systems, such as hospitals, libraries, exhibition centers, and websites
This networking topology enables RG-S2900-E V3 series to cooperate with convergence switches (eg.RG-S5750-H) in an entire building and core switches (eg.RG-N18000 series) in the core area to provide gigabit services for desktops. The 10G high-bandwidth links converge in the core area to satisfy user requirements for increasing information volumes in universities, libraries, laboratories, financial centers, offices, and exhibition centers.
RG-S2928G-E V3
RG-S2952G-E V3
Ruijie Networks
