RG-S6120-20XS4VS2QXS |
Basic specifications |
Fixed ports |
20 x 1G/2.5G/10GBASE-X SFP+ ports* 4 x 10G/25GBASE-X SFP28 ports, 2 x 40GBASE-X QSFP+ ports, Support up to 32 x 10G ports, 2 modular power slots, 2 modular fan slots |
Management ports |
1 MGMT port 1 console port |
Switching capacity |
2.56Tbps/25.6T |
Forwarding rate |
570Mpps/1260Mpps |
ARP Table |
Up to 16K |
Number of MAC addresses |
Routing Table Size |
16K/16K |
ACL Entries |
Up to 2500 |
Product Features |
VLAN |
4K 802.1Q VLAN Port-based VLAN Private VLAN GVRP Super VLAN |
QinQ |
Basic QinQ |
Link aggregation |
LACP (802.3ad) |
Port mirroring |
Flow-based mirroring Many-to-one mirroring, One-to-many mirroring RSPAN Link aggregation mirroring |
Multiple Spanning Tree (MST) Instances |
64 |
Spanning tree protocols |
STP, RSTP, MSTP |
128 |
DHCP |
DHCP Server DHCP Client DHCP Snooping DHCP Relay IPv6 DHCP Snooping IPv6 DHCP Client IPv6 DHCP Relay |
IPv6 protocols |
IPv6 addressing, ICMPv6, Path MTU Discovery |
IP routing |
Static routing RIP, RIPng OSPFv2, OSPFv3, IS-ISv4, IS-ISv6 BGP4, BGP4+ Policy Based Routing ECMP |
IGMP v1/v2/v3, IGMP proxy IGMP v1/v2/v3 snooping IGMP filtering, IGMP fast leave PIM-DM, PIM-SM, PIM-SSM MLD Snooping, MLD MSDP |
ACL & QoS |
ACL |
Various hardware-based ACLs: Standard IP ACL (Based on IP address) Extended IP ACL (Based on IP address and TCP/UDP port number) Extended MAC ACL (Based on source and destination MAC addresses and Ethernet type) Time-based ACL Expert ACL (Based on the flexible combination of VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port, protocol type and time) ACL80 IPv6 ACL |
QoS |
Port-based traffic recognition Port-based speed limit 802.1p/DSCP/TOS traffic classification 8 priority queues per port Queue scheduling algorithms: SP, WRR, DRR, SP+WRR, SP+DRR, RED/WRED |
Filter unauthorized MAC addresses Broadcast storm suppression Hierarchical management by administrators and password protection RADIUS and TACACS+ SSH BPDU Guard CPP, NFPP |
Management |
SNMP, CLI (Telnet/Console), RMON (1,2,4,9), Syslog, NTP, SNMP over IPv6, IPv6 MIB support for SNMP, Telnet v6, FTP/TFTP v6, DNS v6, NTP for v6, Traceroute v6 Support sFlow to sample the packets of the switch traffic using the random sampling technology of data stream |
VSU (virtualization technology for virtualizing multiple devices into 1); GR for RIP/OSPF/BGP; BFD; G.8032 (ERPS), REUP; RLDP; 1+1 power redundancy; Hot-swappable power module and fan module |
VSU (Virtual Switch Unit) |
Up to 2 stack members |
Physical Specifications |
Power supply |
Supported power module: RG-PA150I-F AC input: 100 to 240VAC; 50/60Hz Maximum voltage range: 90 to 264VAC; 47/63Hz HVDC input: Maximum voltage range: 192 to 288 VDC Rated current per input: 3A |
Power Consumption |
<85W |
Power Surge Protection |
4KV (MGMT Port) Power Supply Module (RG-PA150I-F): common mode 6KV/difference mode 6KV |
Fan |
Support 2 pluggable modular fans with front and rear air ducts Support fan speed adjustment and malfunction alert |
Temperature alarm |
Support temperature alarm function |
Temperature |
Operating temperature: 0°C to 50°C Storage temperature: -40°C to 70°C |
Humidity |
Operating humidity: 10% to 90%RH Storage humidity: 5% to 90%RH |
Operating Altitude |
0 to 5,000m |
Dimensions (W x D x H) (mm) |
440 * 330 * 43.6(W * D * H,mm) |
Rack Height |
1RU |
30 Years |
Safety Standards |
GB4943-2011 EN 62368-1:2014+A11:2017 |
Emission Standards |
GB9254-2008 CLASSA EN 55032:2015+AC:2016 EN 61000-3-2:2014 EN 61000-3-3:2013+A1:2019 EN 55035:2017 ETSI EN 300 386 V2.1.1 (2016-07) |
20 1G/10GBASE-X SFP+ ports, 4 10G/25GBASE-X SFP28 Ports, 2 40GBASE-X QSFP+ ports, support up to 32 10G ports, 2 modular power supply slots (at least one RG-PA150I-F power module), 2 modular fan slots (2 fan modules are equipped by default) |
RG-PA150I-F |
150W AC power module for RG-S6120-20XS4VS2QXS |
10G LC interface module for SFP+ ports (62.5/125μm: 33m; 50/125μm: 66m; 300m when the modal bandwidth is 2000MHz•km) |
10G LC interface module for SFP+ ports (1310nm, 10km) |
10G LC interface module for SFP+ ports (1550nm, 40km) |
VG-SFP-SR-MM850 |
25G fiber module VG-SFP-SR-MM850 |
VG-SFP-LR-SM1310 |
25G fiber module VG-SFP-LR-SM1310 |
10G SFP+ optical cable, 1 meter, including one cable + both side transceivers |
10G SFP+ optical cable, 3 meters, including one cable + both side transceivers |
10G SFP+ optical cable, 5 meters, including one cable + both side transceivers |
VG-SFP-AOC5M |
25G SFP+ optical cable (including both side transceivers), 5 meters |
40G-QSFP-SR-MM850 |
40G SR fiber module for QSFP+ ports (OM3/OM4 MPO, 8-core, 850nm, 100m with OM3 fiber, 150m with OM4 fiber) |
40G-QSFP-LR4 SM1310 |
40G LR single-mode fiber module for QSFP+ ports, transmission distance up to 10km (LC, 2-core, 1310nm) |
40G-AOC-5M |
40G QSFP+ optical cable, 5 meters, including one cable + both side transceivers |
40G-AOC-10M |
40G QSFP+ optical cable, 10 meters, including one cable + both side transceivers |
