RG-N18014-E Switches - 1
RG-N18014-E Switches - 2
RG-N18014-E Switches - 3
RG-N18014-E Switches - 4
RG-N18014-E Switches - 5
RG-N18014-E Switches - 6
RG-N18014-E Switches - 7
RG-N18014-E Switches - 8
RG-N18014-E Switches - 9
RG-N18014-E Switches - 10
RG-N18014-E Switches - 11
RG-N18014-E High-density Large-buffer Core Switch for Cloud Architecture Network
RG-N18014-E
Front Panel
Rear Panel
Eight line card slots,
M18000E-8SFX
8 x SFX 10GE ports
M18000E-8SFG
8 x SFG GE ports
M18000E-HCA
20 x 10GE optical ports
4 x 100GE optical ports
Low CPU usage Low CPU usage
Faulty Optical Port Isolation
Visualization Visualization
Virtualization Virtualization
N18010-E
N18014-E
Supervisor module slot
Line card slot
Switch fabric module slot
14,200 Mpps
21,000 Mpps
19.2 Tbps
28.8 Tbps
Number of MAC address
XA card: 4,000
XB card: 10,000
HCA card: 10,000
HCA card: 512,000
XB card: 96,000
HCA card: 96,000
XA card: 4,000
XB card: 4,000
HCA card: 4,000
HCA card: 1,000,000
XA card: 2,000
XB card: 2,000
HCA card: 2,000
● XA card:
Ingress: 7,000
● XB card:
Egress: 4,000
● HCA card:
Ingress: 24,000
Egress: 4,000
43.6 kg (96.12 lbs)
68.3 kg (150.58 lbs)
Supervisor module:
Line card:
Supervisor module:
Line card:
Flash memory: 8 GB
SDRAM: DDR4 4 GB
M18000E-CM: 60 W
M18000E-48GT4XS-XA: 85 W
M18000E-48SFP4XS-XA: 117 W
M18000E-24GT8SFP8XS-XA: 95 W
M18000E-32XS-XB: 149 W
M18000E-52XS-XB: 250 W
M18000E-12CQ-XB: 240 W
M18000E-HCA: 280 W
HCA-20XS: 30 W
HCA-4CQ: 20 W
M18010E-FE-X I: 50 W
M18000E-FE-X II: 160 W
M10C-FAN: 216 W
M18000E-CM: 60 W
M18000E-HCA: 280 W
HCA-20XS: 30 W
HCA-4CQ: 20 W
M14FAN-F: 360 W
RG-PA600I: 600 W
RG-PA1600I:
●  90 to 180 V AC; 1,200 W
≥ 200,000 hours
0°C to 50°C (37°F to 122°F)
RG-N18000-E Series
IPv4 and IPv6 GRE tunnel
MLDv1 snooping
MPLS L3VPN
MPLS 6VPE and MPLS 6PE
MPLS IPv6
IEEE 802.1p
IEEE 802.1X
IPv4/IPv6 ECMP
VLAN mirroring
FTP, SFTP, TFTP, and Xmodem
Web-based NMS
LAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv6
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Layer 2 VXLAN bridge
Layer 3 VXLAN gateway
RG-N18010-E
RG-N18014-E
M18000E-CM
M18000E-CM II
Power Modules and Fan Modules
RG-PA600I
RG-PA1600I
SFUs
M18010E-FE-X I
M18000E-FE-X II
M18000E-32XS-XB
M18000E-52XS-XB
M18000E-12CQ-XB
M18000E-48GT4XS-XA
M18000E-48SFP4XS-XA
M18000E-8SFX
M18000E-8SFG
M18000E-HCA
HCA-20XS
HCA-4CQ
