RG-S2910-24GT4XS-E 24-port Gigabit access switch, Four 10G Uplink Ports
Full gigabit access to LANs in large enterprise parks, gigabit access to commercial systems.
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
Accurate traffic statistics
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
24 x 10/100/1000 BASE-T ports
48 10/100/1000 BASE-T ports
Fans modules
Fixed fans
Fixed fans
128Gbps
176Gbps
96Mpps
132Mpps
RAM
512MB
16K
In: 1,500
Out: 500
Lightning
Protection on
Power Port
Common Mode
6KV/Differential
Mode 6KV
Lightening
Protection on
Communication
Port
Common Mode 6KV
440 × 260 × 43.6
440 × 260 × 43.6
≤3.5kg
≤4kg
AC input: 100V to 240V AC
HVDC input: 192V to 290V DC
90V to 264V AC
90V to 264V AC
Input current
0.5A to 0.1A
0.8A to 0.5A
24W
50W
MTBF (hours)
0°C to 50°C
-40°C to 70°C
10% to 90%RH
5% to 95%RH
IEC 60950-1, EN 60950-1
Emission
Standards
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
4K 802.1q VLANs
MAC-based VLAN
Protocol-based VLAN
IP subnet-based VLAN
Guest VLAN
N:1 VLAN switching
1:1 VLAN switching
Standard/Extended/Expert ACL
Extended MAC ACL
ACL logging
ACL counter
ACL remark
Global ACL
ACL redirect
Time-based ACL
Router ACL
VLAN ACL
Port-Based ACL
Dynamic QoS
Over devices mirroring
VLAN-based mirroring
VLAN-filtering mirroring
AP-port mirroring, RSPAN
ERSPAN
Spanning Tree
Protocols
IPv6 DHCP snooping
IPv6 DHCP client
IPv6 DHCP relay
DHCP Snooping Option 82
Layer 2 protocols
128
OpenFlow 1.0 & 1.3
VSU (Virtual
Switch Unit)
IPv4/ IPv6 static route
IPv6
Basic protocols
VSU features
Management features
CLI (Telnet / Console)
SSH
NTP/SNTP, FTP, TFTP
HTTP or HTTPS
Hot Patch
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
RG-S2910C-24GT2XS-HP-E
RG-S2910C-48GT2XS-HP-E
Optional Accessories
M2910-01XS
M2910-02XS
RG-M5000E-DC500P
