RG-S5350-48GT4SFP-P-E Switches - 1
RG-S5350-48GT4SFP-P-E Switches - 2
RG-S5350-48GT4SFP-P-E Switches - 3
RG-S5350-48GT4SFP-P-E Switches - 4
RG-S5350-48GT4SFP-P-E Switches - 5
RG-S5350-48GT4SFP-P-E Switches - 6
RG-S5350-48GT4SFP-P-E 48-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 1GE Uplink
Layer 3 Compact Access Switch for 1GE Uplink RG-S5350-48GT4SFP-P-E
Passed anti-corrosion tests, with the proven capability to withstand exposure to moisture, ensuring durability in severe environments.
Virtual Switching Unit (VSU) ensures flexible networking and high performance.
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-12GT4XS-P-E
RG-S5350-24GT4XS-P-E
RG-S5350-48GT4XS-P-E
Fixed service ports
4 x 1GE/2.5GE/10GE SFP+ ports
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
RG-S5350-24GT4SFP-P-E
Fixed service ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
4 x 1GE SFP ports
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
94 Mpps
125 Gbps
DDR4 1GB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
50 Mpps
94 Mpps
50 Mpps
94 Mpps
67 Gbps
125 Gbps
67 Gbps
125 Gbps
DDR4 1GB
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Unit weight
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
3.25 kg (7.17 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
Mounting
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fixed power supply: 40 W
Leakage current
≤ 3.5 mA
Built-in power supply: 409 W
35 W (without PoE load)
405 W (full PoE load)
52 W (without PoE load)
Leakage current
≤ 3.5 mA
The maximum power is 370 W.
The maximum power is 405 W.
supported
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
Built-in power supply: 40 W
Leakage current
≤ 3.5 mA
●AC input
Fixed power supply: 409 W
Fixed power supply: 460 W
Leakage current
≤ 3.5 mA
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
Fanless, quiet, < 20 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
27℃(80.6°F): 32 dB
27℃(80.6°F): 35 dB
RG-S5350-E Series
PIM SMv6, and PIM-SSMv6
Extended IP (hardware ACLs
IPv6 ACLon IP addresses)
Multiple AAA modes
BFD, NSR, VRRR, VRRP+
Basic LACP
SPAN, RSPAN
CLI (Telnet/Console)
1:1 mirroring
N:1 mirroring
1:N mirroring
RG-S5350-24GT4XS-E
RG-S5350-48GT4XS-E
RG-S5350-24GT4SFP-E
RG-S5350-48GT4SFP-E
