RG-CS85-48GT4XS-D Switches - 1
RG-CS85-48GT4XS-D Switches - 2
RG-CS85-48GT4XS-D Switches - 3
RG-CS85-48GT4XS-D Switches - 4
RG-CS85-48GT4XS-D Switches - 5
RG-CS85-48GT4XS-D Switches - 6
RG-CS85-48GT4XS-D Switches - 7
RG-CS85-48GT4XS-D Switches - 8
RG-CS85-48GT4XS-D Switches - 9
RG-CS85-48GT4XS-D Switches - 10
RG-CS85-48GT4XS-D Switches - 11
RG-CS85-48GT4XS-D Switches - 12
RG-CS85-48GT4XS-D Switches - 13
RG-CS85-24GT8XS-D
RG-CS85-24SFP/8GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
24 x 10/100/1000BASE-T ports, 8 x 1GE/10GE SFP+ ports
24 x 1GE SFP ports
  • Ports 1 to 16 are 100/1000 Mbps SFP ports
  • Ports 1 to 8 are 1GE SFP/RJ45 combo ports (100/1000BASE-X, 10/100/1000BASE-T)
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports
Fan module
3 fixed fans
3 fixed fans
3 fixed fans
2 modular fans
3 modular fans
Expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Ingress: 7,000
4.4 kg (9.70 lbs)
5.5 kg (12.12 lbs)
5.3 kg (11.68 lbs)
Dual-core CPU, 1.2 GHz
4 GB
4 GB
4 GB
4 GB
4 GB
<110 W (non-PoE)
<1,590 W (PoE full load)
<150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
176 V AC to 290 V AC, 1000 W
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
200 V to 240 V
DC: -48 V to -60 V
AC: 100 V to 240 V
DC: -48 V to -60 V
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V
AC: 176 V to 264 V
DC: -38 V to -75 V
AC: 90 V to 264 V
DC: -36 V to -75 V
≥ 1,051,000 hours
≥ 823,000 hours
≥ 963,000 hours
≥ 832,000 hours
≥ 788,000 hours
45°C: 56.2 dB
45°C: 57.1 dB
45°C: 57.9 dB
27°C: 50 dB
45°C: 65 dB
27°C: 53 dB
45°C: 68 dB
Power port: 6 kV/6 kV
RG-CS85 Series
RG-CS85-24GT8XS-D
24 x 10/100/1000BASE-T ports, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
24 x 1GE SFP ports (ports 1 to 16 are 100/1000 Mbps SFP ports , ports 1 to 8 are 1GE SFP/RJ45 combo ports), 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-D
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-HPD
48 x 10/100/1000BASE-T ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.)
RG-CS85-48SFP4XS-D
48 x 1GE SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
CM85-4XS2CQ
150 W AC power supply module
