RG-S5760C-24GT8XS-X |
RG-S5760C-48GT4XS-X |
RG-S5760C-24SFP8GT8XS-X |
RG-S5760C-48SFP4XS-X |
RG-S5760C-48GT4XS-HP-X |
Fixed port |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
24 x 1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 2 x power supply module slots |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 3 x modular fans, 2 x power supply module slots |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 2 x power supply module slots, supporting PoE/PoE+ |
Fan module |
Two built-in fan modules Fan speed regulating and fault alarms |
Three pluggable fan modules |
Two pluggable fan modules |
Power module |
Two power modules The switch can be powered on by either one or dual power modules. If both power modules are used, the switch works in the power redundancy mode. |
Management port |
One MGMT port, one console port, and one USB port, compliance with the USB2.0 standard |
Expansion slot |
Two expansion slots are reserved for expansion modules and supervisor modules. One expansion slot is reserved on the RG-S5760C-48GT4XS-HP-X and RG-S5760C-48SFP4XS-X. |
Packet forwarding rate |
512 Mpps |
488 Mpps |
512 Mpps |
488 Mpps |
488 Mpps |
Switching capacity |
688 Gbps |
656 Gbps |
688 Gbps |
656 Gbps |
656 Gbps |
Number of MAC addresses |
64,000 |
64,000 |
64,000 |
64,000 |
64,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
4,000 mmu-enhance: 3,000 |
14,000 |
14,000 |
14,000 |
14,000 |
14,000 |
2,000 mmu-enhance: 1,500 |
In: 7,000 Out:1,500 |
Number of IGMP groups |
4,000 |
Number of MLD groups |
1,000 |
Number of VSU members |
8 |
440 mm x 340 mm x 44 mm (17.32 in. x 13.39 in. x 1.73 in.) |
442 mm x 420 mm x 43.6 mm (17.40 in. x 16.54 in. x 1.72 in.) |
4.4 kg (9.70 lbs) |
4.5 kg (9.92 lbs) |
4.3 kg (9.48 lbs) |
5.3 kg (11.68 lbs) |
5.5 kg (12.13 lbs) |
1.2 GHz dual-core CPU |
Storage |
Flash memory: 4 GB SDRAM: 1 GB |
Flash memory: 4 GB SDRAM: 2 GB |
Data packet buffer |
1.2MB |
Power and Consumption |
< 60 W (excluding expansion modules) < 85 W (including expansion modules) |
< 70 W (excluding expansion modules) < 95 W (including expansion modules) |
< 77 W (excluding expansion modules) < 102 W (including expansion modules) |
< 105 W (excluding expansion modules) < 125 W (including expansion modules) |
Without PoE load: ≤ 110 W With PoE full load: ≤ 1,590 W |
Maximum output power |
RG-PA70IB: 70 W RG-PA150I-F: 150 W RG-PA150IB-F: 100 V to 240 V, 150 W RG-PD150IB-F: 48 V DC to 60 V DC, 150 W |
RG-PA600I-P-F: 600 W (PoE: 370 W) RG-PD600I-P-F: 600 W (PoE: 370 W) RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000 W; 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
Rated input voltage |
AC input Rated voltage range: 100 V to 240 V Frequency: 50 Hz/60 Hz HVDC input: Rated voltage range: 240 V LVDC input: Rated voltage range: 48 V DC to 60 V DC |
AC input Rated voltage range: 200 V to 240 V Frequency: 50 Hz/60 Hz DC input: Rated voltage range: 48 V to 60 V |
AC input Maximum voltage range: 90 V to 264 V HVDC input: Maximum voltage range: 192 V to 288 V LVDC input: Maximum voltage range: 36 V DC to 75 V DC |
AC input Maximum voltage range: 176 V to 264 V DC input: Maximum voltage range: 38 V to 75 V |
AC input Maximum voltage range: 90 V to 264 V DC input: Maximum voltage range: 36 V to 75 V |
120 years |
110 years |
94 years |
90 years |
95 years |
Primary Airflow |
Air intake from left and front panel, and air exhaust from right |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) V1.X+M5000X4XS2CQ: 0 to 40°C (32°F to 104°F) |
0°C to 45°C (32°F to 113°F) |
10% to 90% (non-condensing) |
5% to 95% (non-condensing) |
Operating altitude |
0 m to +5,000 m (0 ft. to +16404.20 ft.) |
Operating noise |
45°C (113°F): 56.2 dB |
45°C (113°F): 57.9 dB |
45°C (113°F): 57.1 dB |
27°C (80.6°F): 50 dB 45°C (113°F): 65 dB |
27°C (80.6°F): 53 dB 45°C (113°F): 68 dB |
Interface surge protection |
RG-S5760-X Series |
Feature |
Ethernet switching |
Super-VLAN and private VLAN |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
DHCPv6 client, DHCPv6 server, and DHCPv6 relay |
DHCPv6 snooping |
IPV6 addressing, ICMPv6, Stateless Address Auto-configuration (SLAAC), and path MTU discovery |
IP routing |
BGP4 and BGP4+ |
ECMP |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 and IGMP proxy |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
MPLS |
MPLS L3VPN |
Port traffic identification |
Port traffic rate limiting |
AAA |
RADIUS and TACAS+ |
Port-based and MAC address-based 802.1X authentication |
HTTPS |
SSHv1 and SSHv2 |
Global IP-MAC binding |
SAVI |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of unauthorized MAC addresses MAC address bypass (MAB) authentication Portal authentication and Portal 2.0 authentication ARP check Dynamic ARP Inspection (DAI) ARP packet rate limiting Gateway ARP anti-spoofing Broadcast storm suppression Hierarchical management of administrators and password protection AAA for device login management MAC Authentication Bypass (SSH) BPDU guard Port protection |
REUP, RLDP, and DLDP |
GR for RIP, OSPF, BGP, and other routing protocols |
BFD |
1+1 power module redundancy |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2c/v3 |
RMON (1, 2, 3, 9) |
SSHv1 and SSHv2 |
Syslog |
NETCONF |
CWMP (TR-069) |
CLI (Telnet/Console), SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnet v6, FTP/TFTP v6, DNS v6, NTP for IPv6, and Traceroute v6 |
RG-S5760C-48GT4XS-HP-E: IEEE 802.3af and 802.3at, uninterruptible power supply upon hot start, and port priority |
VXLAN |
With VXLAN, a Layer 2 logical network can be built based on a Layer 3 network through software upgrade. |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power module slots Purchase at least one RG-PA150IB-F module. |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fixed fans, 2 x power module slots (Purchase at least one RG-PA150IB-F module.) |
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x built-in fans, 2 x power module slots (Purchase at least one RG-PA150IB-F module.) |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power module slots Purchase at least one RG-PA150IB-F module. |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power module slots Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F/RG-PD600I-P-F module. |
M5000X-4XS2CQ |
4 x 10GE SFP+ ports and 2 x 100GE QSFP28 ports |
M5000X-4QXS* |
4 x 40GE QSFP+ ports |
RG-PA150IB-F |
150 W AC power module |
RG-PA600I-P-F |
600 W PoE AC power module |
RG-PA1000I-P-F |
1000 W PoE AC power module |
RG-PD600I-P-F |
600 W PoE DC power module |
MINI-GBIC-ZX50-SM1550 |
MINI-GBIC-ZX100-SM1550 |
10GE LC module (62.5/125 μm: 33 m (108.27 ft.); 50/125 μm: 66 m (216.54 ft); transmission for 300 m (984.25 ft.) when modal bandwidth is 2000 MHz*km), applicable to SFP+ ports |
10GE SFP+ optical cable, 1 m (3.28 ft.), including one cable and two interface modules |
10GE SFP+ optical cable, 3 m (9.84 ft.), including one cable and two interface modules |
10GE SFP+ optical cable, 5 m (16.40 ft.), including one cable and two interface modules |
